![](https://galvanizeit.org/uploads/news/_250x180_crop_center-center_65_none/LCCC_Report.jpg)
Track Elements
Hot-dip galvanizing's maintenance-free corrosion protection allows for less stress and worrying and more freedom to focus on higher priority task.
Keeping rail lines and track in safe, consistent operation is key whether to move freight or passengers. Therefore, much of a railroad or transit authority’s focus is, rightly so, on the track itself. However, there are many elements and ancillary items along the track that also play a pivotal roll in uninterrupted, safe operation.
Many of these elements can benefit from the use of hot-dip galvanized steel. Because HDG provides decades of maintenance-free corrosion protection, these ancillary items can be galvanized, installed and then largely ignored while they do their job for 70+ years. Hot-dip galvanizing is built to withstand atmospheric elements from sun and heat to rain and snow – making it a great fit for track elements across the country whether in rural or urban areas.
Track Elements Components
Access Points |
Cables |
Cable Supports |
Catwalks |
Columns |
Fasteners |
Fencing |
Grating |
Ground Anchors |
Guardrail |
Ladders |
Light Poles |
Lower Arms |
Overhead Sign Support |
Railing |
Reinforcing Steel |
Reinforced Earth Walls |
Signal Light Poles |
Signal Supports |
Sign Supports |
Sound Barriers |
Stairways |
Steel Divider Barrier |
Substations |
