Skip to content
HDG Attributes
Hot-dip galvanizing plays a crucial role in infrastructure projects, providing durable and long-lasting protection against corrosion. Hot-dip galvanized (HDG) steel has been used for over 175 years to protect steel from corrosion and is widely used in the majority of markets supported by the Bipartisan Infrastructure Law (BIL). In transportation, hot-dip galvanizing is employed to safeguard bridges, highways, and other products from rust and degradation caused by exposure to moisture, chemicals, and harsh weather conditions. The galvanized coating acts as a barrier, preventing corrosion and extending the lifespan of these vital structures. Additionally, hot-dip galvanized steel is utilized in the construction industry for applications such as guardrails, lighting poles, transmission towers, and sign supports. These components are exposed to environmental elements and require reliable corrosion protection to ensure their structural integrity over time.
Hot-dip galvanized coatings provide a cost-effective and low-maintenance solution, reducing the need for frequent repairs or replacements. Moreover, hot-dip galvanizing is used in electrical transmission and distribution infrastructure, where galvanized steel structures, such as poles and substation frameworks, offer superior corrosion resistance in various climates. Overall, the use of hot-dip galvanizing in infrastructure projects ensures longevity, sustainability, and cost-effectiveness by mitigating the detrimental effects of corrosion.
  • Card design guide
    Design Guide: Products Galvanized After Fabrication
    Design and fabrication practices for optimizing the quality of HDG coatings. This guide contains more than 30 full-color illustrations.
  • Card specifiers guide
    Hot-Dip Galvanizing for Corrosion Protection: A Specifier's Guide
    This publication discusses why specifiers choose HDG steel beyond just corrosion protection.
  • Card performance of HDG
    Performance of Hot-Dip Galvanized Steel Products
    This publication details hot-dip galvanized steels performance in various environments (atmosphere, water, soil, etc.).
  • Card sustainable design
    HDG for Sustainable Design
    Discusses the sustainability of hot-dip galvanized steel by examining both the environmental and economic impacts of utilizing the product.
  • Card duplex systems
    Duplex Systems: Painting Over Hot-Dip Galvanized Steel
    This publication provides an overview of duplex coated applications/benefit and surface preparation procedures.
  • Card aess guide
    HDG Architecturally Exposed Structural Steel (AESS) Guide
    A guide for specifiers on design and communication best practices when specifying HDG steel with aesthetics requirements.
  • Card inspection guide
    Inspection of Hot-Dip Galvanized Steel Products
    This guide covers the inspection procedures for HDG steel including a visual inspection guide with photo examples.
  • Card HDG bridges
    Design Guide: HDG Bridges
    Best practices to ensure the highest quality, longest lasting HDG steel bridges.
  • Card spec guide rebar
    Specifier's Guide: HDG Reinforcing Steel
    Performance of HDG rebar in concrete along with information about design, specification, fabrication, and installation concerns.
  • Card alt energy sustainable
    Sustainable Solutions in Alternative Energy
    Renewable energy sources provide sustainable, clean energy and likewise should be constructed from sustainable building materials such as hot-dip galvanized steel.
  • Parking high Page 01
    Hot-Dip Galvanized Parking Structures
    Explore the social benefits, economic savings, and environmental advantages of utilizing hot-dip galvanized steel to enhance your parking structure.
  • Card HDG Fasteners
    Hot-Dip Galvanized Fasteners
    This publication explains how and why hot-dip galvanized fasteners provide superior protection for connections, as well as some design considerations when using galvanized fasteners.
  • Card zinc coatings
    Zinc Coatings
    Designed to assist specifiers with the selection of zinc coatings for corrosion protection by discussing the various zinc coatings and their characteristics.
Calculators, Tools & Other Resources
  • Galv Locator ad
    Galvanizer Locator
    Find a hot-dip galvanizer near you by using our Galvanizer Locator. Search by address, zip, state/province, or company name. Kettle sizes for all plants are listed.
  • LCCC Bridge
    Life-Cycle Cost Calculator
    Use the Life-cycle Cost Calculator to compare the initial and life-cycle cost of hot-dip galvanizing to other common coating systems.
  • ZCLP Power
    Zinc Coating Life Predictor
    Use the Zinc Coating Life Predictor to estimate the atmospheric corrosion rate of hot-dip galvanized (zinc) coatings in your area.
  • Pregressive dip calc
    Progressive Dip Calculator
    This is a tool used to confirm whether an article of known dimensions can be progressive-dip galvanized within a galvanizing kettle of known dimensions.
  • Time to first maintenance chart ad
    Time to First Maintenance
    Use our TFM Chart to estimate when maintenance would be required to extend the life of HDG steel in typical North American environments.
Continuing Education Seminars - Free PDHs / LUs (HSW)
  • GI Seminar Core
    Galvanize It! Core Seminar
    This course will examine the hot-dip galvanizing process as well as other zinc coatings, and detail the intrinsic benefits galvanizing provides.
  • GI Seminar Design
    Galvanize It! Seminar: Design
    The course examines the hot-dip galvanizing process, ASTM specifications, design best practice, inspection, and preparing the galvanized surface for painting/powder coating.
  • GI Seminar SD
    Galvanize It! Seminar: Sustainable Development
    This course examines the sustainable aspects of HDG including zinc and the environment, LEED, life-cycle assessment (LCA), life-cycle cost (LCC), environmental and economic case studies.
  • GI Seminar Duplex
    Galvanize It! Seminar: Duplex Systems
    This seminar provides an overview about hot-dip galvanized steel and the synergistic benefits when coated with a paint or powder coating on top.
  • GI Seminar Bridge
    Galvanize It! Seminar: Bridge Design
    Understanding both the benefits and limitations of galvanized steel will assist bridge engineers in evaluating if hot-dip galvanizing is a solution for their bridge project.
  • GI Seminar Transportation
    Galvanize It! Seminar: Transportation
    This seminar provides an overview about hot-dip galvanized steel and how it can be used in in the transportation industry, from bridges and highways to mass transit applications.
  • GI Seminar Rebar
    Galvanize It! Seminar: Reinforcing Steel
    This seminar will help specifiers understand the benefits of hot-dip galvanized rebar in concrete and provide design and specification information specific to hot-dip galvanized rebar.
  • GI Seminar Parking
    Galvanize It! Seminar: Parking
    This seminar provides an overview of the social, economic, and environmental benefits of incorporating hot-dip galvanized steel in parking structures.
  • GI Seminar Power
    Galvanize It! Seminar: Power Infrastructure
    This seminar provides an overview about hot-dip galvanized steel and how it can be used in power generation, transmission and distribution projects.
  • GI Seminar Mining
    Galvanize It! Seminar: Mining
    This seminar will introduce you to the basics of specifying, designing, and inspecting hot-dip galvanized steel with an emphasis on its use in the mining industry.
Galvanized Steel Studies - Video Series
  • GSS Buffalo Creek
    Galvanized Steel Studies - Buffalo Creek Bridge
    All of the steel in the Buffalo Creek Bridge is galvanized. We interviewed the County & Chief Engineer on the project to learn why they chose HDG steel.
  • GSS Calgary LRT
    Galvanized Steel Studies - Calgary LRT Refurbishment
    When the city of Calgary was ready to refurbish the 7th Avenue Light Rail Transit (LRT) System learn how hot-dip galvanizing was the logical choice.
  • GSS Omaha Transmission
    Galvanized Steel Studies - Omaha Transmission Line
    Learn how the Omaha Public Power District's (OPPD) decision to use HDG steel has protected its transmission lines since their installation in 1971.
  • GSS Captain Trash Wheel
    Galvanized Steel Studies - Inner Harbor Water Wheels
    Learn how hot-dip galvanized steel protects water wheels that are capable of removing 50,000 pounds of trash per day in this corrosive environment.
